EZCad 2 compactible/clone board
Hi,
I recently purchase a used laser which came with a JCZ clone board, identical to the person in this post:
As with this other post, the vid/pid is 9588/9980.
I am on linux and the laser does not seem to be recognized. The shell output clearly seem to iterate over it but it does not seem to do anything with it:
Found port: PID 60000 VID 4292
Manufacturer: "Silicon Labs"
Product: "CP2104 USB to UART Bridge Controller" on "ttyUSB0"
attempting connection... 115200, DTR setting: false
attempting connection... 115200, DTR setting: true
Found port: PID 0 VID 0
Manufacturer: ""
Product: "" on "ttyS0"
Vend: 38280 Prod: 39296
Empty filename passed to function
I also gave it a try on windows 10. I was able to replace the driver with WinUSB with zadig, but lightburn still does not seem to recognize the laser.
Any tip on how to proceed would be appreciated !
Quick update, after installing and dei-nstalling the driver a number of time, I managed to get it working on windows, but still nothing on Linux.
Quick update …
I managed to kind of get it to work on linux…
When working on windows, I realized the the board start with enumerating as 9588:9980 and as soon as it is connected, re-enumerate as 9588:9899. I think the driver or software is loading the firmware.
If I first connect it to windows, then re-connect it to linux without re-starting the laser, everything works.
Does anyone have a solution to get this to work all on linux ?
Hello,
I am having the exact same issue. I have tried a fresh Ubuntu 20.04 LTS install and the newest Lightburn and it detects nothing. I made the permissions changes in udev, but the issue is the VID:PID.
I even tried running as root out of frustration to make sure that it wasn’t a strange permissions issue.
In lsusb it shows the same ID as yours: ID 9588:9980
dmesg shows:
[ 8094.603155] usb 2-2: new high-speed USB device number 16 using xhci_hcd
[ 8094.751420] usb 2-2: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[ 8094.751426] usb 2-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 8094.751429] usb 2-2: Product: USB 2.0 Hub
[ 8094.752622] hub 2-2:1.0: USB hub found
[ 8094.752667] hub 2-2:1.0: 4 ports detected
[ 8095.139270] usb 2-2.1: new high-speed USB device number 17 using xhci_hcd
[ 8095.339373] usb 2-2.1: New USB device found, idVendor=9588, idProduct=9980, bcdDevice= 0.01
[ 8095.339379] usb 2-2.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 8095.539074] usb 2-2.2: new full-speed USB device number 18 using xhci_hcd
[ 8095.759525] usb 2-2.2: not running at top speed; connect to a high speed hub
[ 8095.760273] usb 2-2.2: New USB device found, idVendor=3689, idProduct=8762, bcdDevice= 2.00
[ 8095.760279] usb 2-2.2: New USB device strings: Mfr=1, Product=1, SerialNumber=0
[ 8095.760282] usb 2-2.2: Product: USBKey
[ 8095.760285] usb 2-2.2: Manufacturer: USBKey
[ 8095.766240] hid-generic 0003:3689:8762.0005: hiddev0,hidraw0: USB HID v1.10 Device [USBKey USBKey] on usb-0000:00:14.0-2.2/input0
I did end up installing EZCad on a old Windows machine and I was able to burn stuff, but it shows up in Device Manager as 9588:9899. I also tried what you suggested, swapping after starting on Windows, but that did not work for me, it still shows up as 9588:9980 in lsusb.
I see in the drivers folder that the .inf has both product IDs:
[BJJCZ.ntamd64]
%JCZUSBDEV%=Install_LMC, USB\VID_9588&PID_9980
%USBLMC%=Install_LMC, USB\VID_9588&PID_9899
I did not try the Windows version of Lightburn, since that laptop is old and out of date, so I did not want to connect it to the Internet to get the trial to run.
If you or anyone else has any ideas, please let me know. I have a fair amount of Linux experience, so I would be glad to work with anyone to try and debug this.
I already run my diode laser on Lightburn in Linux, which I love! I just bought the fiber and it would be a major bummer if I have to go back to Windows/EZCad.
Thanks
Hi Dave,
I lied a bit, when I said switching, I actually just do a usb redirection via qemu. This mean the board is actually always powered via usb.
My experience with usb is limited, but I might do some reversing on driver to see if I can figure out how the firmware loading is happening and see if I can replicate it on Linux.
I created a simple tool that extract the firmware from the windows driver and load it:
Let me know if this work for you
Charles,
You are amazing!!! I tested your script and it works perfectly!!! I am able to use my Fiber in LightBurn on Linux!
I really appreciate you responding so quickly and I never expected a solution that fast, but WOW!
I am in awe of how you figured that out so quickly and effectively.
Thank you very much,
Dave
I am happy that I help … that was actually quite fun to play with …
Charles,
It is a great help. I created a bash script to run the your Python script and then start LightBurn, which I then added as a desktop shortcut. So, it works as it normally would.
I am not sure if your fix can be incorporated into LightBurn, but hopefully this will help others in the same situation.
Again, Thank You!
Dave
