In another thread its mentioned that the interlock feature would be added in 1.3, I have 1.4 and I cant find it, is it implemented?
https://forum.lightburnsoftware.com/t/galvo-door-interlock-io-setting/74064
You were not very clear about the settings… In the device setting menu you can specify what pin is associated to the door protection…
Did you change it and see what happens?
Don’t know what it might buy you…
Lightburn might not be able to act on it, but it’s in the controller… Maybe the controller will prevent it from executing?
Good luck
I cant belive I did not see that myself, now it works ![]()
The door switch was on pin14
You found it before I did.
I found this when my foot switch wouldn’t work…
In the Device Settings, the active pin squares are dynamic. You can press the switch and the box will turn green… You can see if it works or in my situation, I didn’t know what pin the foot switch was using.
It just surprised me…
@Jeeybee does Lightburn detect it?
Yes that was how I found out which pin it was.
