A feature I would like to suggest is to utilize the camera to track registration marks within a file and then use that data to align the cuts.
This would greatly simplify the alignment of multi-process parts (parts this have been previously printed etc) and would also work very well with fixtures such as jigs for repeatability.
Thank you. LightBurn provides a place for suggested features and allow folks to vote their support.
Please put your requests and suggestions there. Helps us track users requests and you will be notified when the status of things you are interested in changes. Please use search prior to new posting as to not create duplicate items.
I have a plan to do something like this. The camera won’t auto-track them, but I’ll allow you to manually tag printed registration marks in a background capture, similar to the way the marker tagging works during camera alignment, and then the output job will be automatically rotated / scaled / skewed to match the tagged markers.
If you want automatic, that will have to wait until after we get head mounted camera support working. Automatic print and cut will be looked at after that.
Has the automatic print and cut with the camera been looking into at all? Print and cut is a great feature but manually it can be a bit cumbersome and time consuming. Select the first mark on the computer, get the dot close on the machine, slow down the speed of the laser head on the machine, get it exact the dot exact, enter the mark on the computer and select the next marker, change the speed on the laser head again so it moves faster to the next mark, slow down the speed of the laser head again to get it exact, enter it on the computer…You get the point.
It would be great if this could be done automatically with a camera.
