Fiber laser Aeon can't find my laser
Hi,
I have an Aeon Pulsar F50 Fiber laser since yesterday.
I am able to find it in the device manager and have installed the drivers.
But I can not find it in Lightburn when I do an automatic search.
For the drivers I had first installed the Lmcv2u
and when that didn’t work, the Lmcv4u
I have also other files for drivers that I have not yet tried. But I have a W10 64x PC so I have not tested the other ones.
Today I have updated my license with Galvo and I have the LightBurn v1.2.00.
I have also reinstalled lightburn so that I was able to select that I also want to use CO2 and fiber lasers.
Is my lightburn version to old, is the type of laser not supported, …?
Thank you very much for every help.
With kind regards,
Jeroen
Did you install the Lightburn drivers or the EZCad2 drivers?
You can only have one or the other installed… did you have Lightburn install the FTDI (I think) drivers?
I don’t have windows, this sounds like a driver issue because if the os can see the device, Lightburn usually connects. The device is clearly there…
Did you run EZCad with it?
Hi Jack,
Thanks for answering.
I had first installed those Lmcv2u / Lmcv4u driver and after that I have reinstalled Lightburn to be able to select the Install EzCad2 driver and FTDI serial driver. So yes, also the FTDI driver is installed (pic shows otherwise).
EZCad itself I have never installed.
Thanks
Can you see the entry in the device manager? It needs to be visible from the OS or you won’t be able to connect.
Have you gone through this thread? It’s pretty clear about drivers…
Good luck
I’d look at this section in the docs. It explains what you are looking for in Device Manager if the LightBurn drivers are installed. You many need to use the ZADig method to swap the drivers, it’s at the end of the docs.
I did see the usb in the device manager as seen as my first picture.
And I had seen the documentation, but had not yet tried the ZADig method.
That was the solution.
That was indeed the solution.
It had not yet succesfully installed the Lightburn drivers.
Now I can add the laser by searching for it.
But it keeps swapping between busy and disconnected.
I am still searching the forum for answers.
Changing the fiber laser from JPT to IPG does not work.
I get in the ready state when only the power is on. But when I turn on the laser button, it keeps switching between bussy and disconnected.
Did you import the Markcfg7 file from the EZCad software they sent you when you created the device in LightBurn? That file has the config info for your machine it it. If you did and it’s still not working, I’d recommend emailing support@lightburnsoftware.com to create a ticket with them for assistance.
Hi Steve,
I have tried it with the Markcfg7 file and indeed it still did not work.
I will clean the drivers and lightburn and reinstall everything one more time and if it then don’t work, I will contact Lightburn support.
Thanks.
Is Lightburn talking to the fiber controller?
Lightburn should show Ready in the top left of the laser window. If it does then it’s not a communications problem, it’s configuration or hardware…
There isn’t much point in removing and re-installing Lightburn and/or the drivers… if Lightburn is connecting…
Follow the problem via the flow … if Lightburn is connecting to the machine, it’s not a driver issue… and probably not a Lightburn issue either.
If it’s toggling between busy and disconnected … I haven’t see that… mine goes to framing then to ready when I turn on the fiber… if that means anything.
Did you swap out the USB cable?
Hi Jack,
Lightburn is connecting when I only put the power on.
But when I put the laser on with an other button on the case, I get busy<->disconnected
And also the message “Unrecognised board signature”
And I have tried already 3 USB cables.
Directly to my laptop and not by a USB hub.
I’d suggest you send a note to support… if the following doesn’t work. Kind of going back to what you’ve already done…
I have not seen it like you describe but I’ve heard of the unrecognized board signature… Generally unloading and reloading isn’t the answer… it just means there’s a bug somewhere… in the drivers or the install/remove software.
This thread had success, but it appears he missed a step in the installation somehow… it’s a Windows machine, so no telling… no mention of the busy/disconnected message.
Good luck…
I also have seen that post.
That’s why I tried with re-installing LightBurn.
And Zadig did help to get my LightBurn to find the laser.
EZCAD itself I have not used yet.
I will contact LightBurn support.
Thanks anyway for your help and time.
We are all interested in getting you up and running… Support is pretty quick and since you followed all the listed debug items… They would be a good choice now.
Include this thread in the email, so they can see what you’ve done…
Good luck…
LightBurn replied and sugested that I should connect my usb with the control board inside the laser.
Because there is a sub cable from the control board to the outside of the laser case that probabebly is faulty or in interference with the power supply who runs along the cable.
It still only works with 1 of my 2 usb cables. so for other people, you need to keep that in mind.
Thank you verry much everyone for the help. And offcourse also LightBurn support.
Edit:
And it does work with fiber IPG as JPT (what it actually is).
