Can anyone tell me why the displayed file is mirrored when I open a file? Is this a setting in Lightburn?
It’s likely because the file was created with a device setup that has a different machine origin configured in Device Settings than the device setup you’re currently using.
jkwilborn
(Jack Wilborn)
April 30, 2022, 9:24pm
3
Hello everyone, so been using LB for a while as a few of your know, all has been well but for some reason, the program/machine has started not homing, if I click home the head moves around 15mm forward, and when I finish a job it now sits in the bottom left corner, normally it homes back to the top left.
Not on all files, I’m running will it do this, today same file it homed top left when the home button was hit, so run a frame and it done as normal sat bottom left where I would usually hit hom…
Just posted a clarification here… maybe that will help
Good luck
sorry answered wrong thread
