Fill and offset fill mode not working after update to .06
After the latest update 1.7.06, is suddenly the fill and offset file mode are not working properly anymore.
I have a Xtool D1 pro running problem free until this update. I have tried to shut down and restart the computer a couple of times as I have shut down the laser a few times. To rule out any problem with my file, i did make a new file and simply drew a circle. When I choose line mode, it perfectly engraves a circle as I would expect. But when I choose fill or offset fill, the laser will the first time turn on the lasermodule and move a little bit and turn off again. When I hit the play button again, it will move on the X axle until it hits the limit switch. When i open the preview screen it looks ok. So the preview screen and behaviour of the laser do not match. Can you help me with this problem please? I did send this message to support but the are closed which is totally understadable but since im in kind a hurry i am hoping someone could help me out in the weekend. Thank you!
I don’t know if it will help, but load a preferences file from before the update. File menu> Preferences> Load Prefs Backup. If that doesn’t work, load your old version of Lightburn until Support has a chance to address it.
https://release.lightburnsoftware.com/LightBurn/Release/
Just curious, are you using the Lightburn xTool Device type or the one from xTool?
Kinda sounds like an issue that was fixed but weird that it just started.
I would check here:
Just to be sure.
Hi, it seems it has something to do with that. Since i followed your instruction i’m able to fill again. but it gives some other issues like the pause button is not working any more. First i tried to load a pref backup like Tim and support said and that didnt work.
Ok, it works again: I installed a 1.6 version. then installed the configuration file again which i found here: Operate xTool D1 Pro with LightBurn - xTool Support Center. Then updated til the latest version. thank you all for helping
