remizik
(remizik)
July 3, 2021, 8:33pm
1
Hello,
is there a way to do the following in one job ?
I’d like the zone “1” to be fill+line without filling the blue circle
The blue circle needs another fill+line parameters.
Or do I need to do it in two jobs ?
thanks
TomWS
(TomWS)
July 3, 2021, 8:41pm
2
Do a boolean operation to create a donut and fill that.
Rick
(Technical Evangelist)
July 3, 2021, 8:56pm
3
If you add another, duplicate ring on the same layer as the largest, you should get what you are after.
Zoomed in Preview to show detail.
This is a good post explaining how LightBurn uses boundaries as a toggle to define what gets filled and what is not.
If you want to invert a vector engraving (Fill layer) you need to add an outline to it. Think about what happens when you scan a circle, compared to the letter ‘O’. The inner ring of the O toggles the fill. If you add another shape (like a square) outside it, it negates the whole thing:
[image]
And a slightly different example, this time done by changing the outer line around the design to a ‘Line’, instead of leaving it as part of the Fill layer:
[image]
In the case above, the design alr…
remizik
(remizik)
July 4, 2021, 8:42am
4
Thanks for your answers but I’m not sure it would allow me to do what I want.
Basically I’d like to engrave something like this:
in one job.
The real project will be using a DXF file, more complex than this but this would be the same principle
bernd.dk
(Bernd )
July 4, 2021, 10:01am
5
it is quite easy, start by engraving the large diameter including the area in the middle, then you engrave layer 2 with the small depression. It is almost the same procedure as metalworking with one lathe, one process after another.
remizik
(remizik)
July 4, 2021, 12:31pm
6
I wanted to avoid that as I already did all the testing for passes/speed/power for specific depths
I guess multiple jobs it is !
