Fill operations are shifted from Line cuts
Hello, having a little issue with my operations.
I am doing some lake maps and using fill for the letters/numbers. Line for road beds and lake cut out. Issue I’m having is to cut down on the running time, I had fill shapes individually turned on. Ran a couple maps and noticed all the fill operations were shifted roughly .1" off from the Line cutting operations. Turned fill back to fill all shapes at once and it fixed it, but it increased run time by close to an hour.
Anyone ever have this issue and is there a easy fix to help me save time?
Thanks
Zach
Laser is a Noua 130watt laser with Rudia controller
DO NOT post your License Key
If your issue requires LightBurn staff attention, please email us at support@LightBurnSoftware.com - this is a public forum
Maybe read this Lightburn Doc:
Show us your preview vs your results
Show us your cuts/layers settings.
Are you using the overscan option?
With out more data, I can suggest increase overscan and turn speed down by 25%
This may be another instance of the PWM Rising Edge Valid misconfiguration that tends to appear only on complex layouts:
Previous discussions:
Remember: Ruida controllers handle the overscan internally, so LightBurn has no control over it.
