Fire Alarm Keeps going off
My Fire alarm keeps going off, however I have cut this particular piece more than one time without an issue, now it wants to sound an alarm.
I can’t get it start the job again, in the same place that it stopped (how do I do that?) I canoe keep wasting my supplies due to they are expensive to replace.
Below is the Code where the error occurs. How do I stop this from happening, at this point, I am wasting my supplies and this is ridiculous when nothing is happening for it even to sound off.
Err:FlameCheck
Alarm:59
One or near line: 4999
Job Halted
Hi,
This won’t be an issue with the Lightburn software, but more likely the Alarm sensitivity on your hardware. What make and model of laser are you using?
Good Day!
My apologizes, I have a xTool D1 Pro. Also, the sensor for the Y Axis, keeps breaking. I have already replaced it once, now I also have to do it again.
  1. How to I stop the scesor from continually breaking and
  2. How to turning off this fire alarm, due to it is turning on/blairing when there is no need too, and it is just doing the passes that I am requesting.
    *In order to cut through 1/4 in birch wood, I have to do 5 passes at least and the alarm Blairs on pass number 2, when I have cut this piece before.
    *Also it will not allow me to cut 2 of the same pieces without it going off. I cut one piece fine, then will sound off on the 2nd piece.
I am just do confused about it.
Please check this other post about the same issue. It appears it is a known problem and you can turn down the sensitivity of the alarm
Ok, Thank You!
