I can’t believe it. DTR enable WORKED.
Thankyou for all your assistance.
Now I have another issue (with Rotary axis) but will investigate more first.
Thanks Again.
Thanks Again.
Thats interesting that Enable DTR worked. We will note this for the future. Do you know what control board you have? I know its ESP-32 based, but is it Barts 6-Pack, or the Fystec, or MKS board?
I can’t speak for Aleka, but I’m using Bart’s ESP32 CNC Development Board v4.1 and I need to have DTR enabled.
I’m just using a generic board connected to an original StepCraft 300 via DB25
This is the one I’m using https://www.jaycar.com.au/esp32-main-board-with-wifi-and-bluetooth-communication/p/XC3800
It’s all working great still and I’ve done about 18+ rotary laser jobs on some microphones with no issue,
except for having to swap the X & Y as the rotary is running in the Y axis not X like most and LB can’t deal with that from what I’ve discovered.
This was easy to do with FluidNC though by sending command to use a different config file, but make it tricky to do jogging, just gotta turn my head sideways to get the axis arrow right
S
