Everything has been working fine, but for some reason my Frame button up and stopped working as intended. I have the box checked in my settings so the frame will start before the project. Now when i click the frame button it will fire the laser. When i hit stop, it makes a project complete sound and restarts the project. The only way to stop it is to pause and then stop. Not sure what I did to change up this setting.
When i have the file i want to use highlighted and hit the frame button, instead of casting an image with the red laser it just starts the project itself. No pre-image down
Hi there! I included a video of what is going on. When i select the image i want to use and hit the frame button so i can see where exactly id be putting tbe laser marking down. Instead of a casting an outline with the red laser it just starts my project
Ah. Didn’t realize you were on a galvo. I’m not very familiar with galvo function although I know there is a unique framing mechanism at play which I assume is contributing to this. Hopefully someone else closer to this can provide more insight.
Apologies I haven’t been clear. When I hit the framing button it starts the laser process as if I am hitting the start button.
Rather than casting an outline. I just instantly starts the laser process. No chance of being able to tell the size or location with the red laser outline physically on my table.
Under device settings on the right it “Start Marking” was set to None by default but for some reason changes to 15 on me. Setting it back to none fixed my issue.
