Frames Perfect but Image is offset to the left
Engraving a 4" round Slate coaster, frames perfect but when the laser starts to engrave the image is offset to the left. Anyone know what will cause this? Using Lightburn with XTool D1 (Not Pro on this one).
By default, xTool has a ‘Laser pointer offset’ in the Device Settings window (‘Edit’ > ‘Device Settings’). Try toggling that off, and instead enabling the laser ‘Fire’ button so that your laser fires when framing.
You should also change the positioning mode to ‘Laser spot’ in xTool’s Creative Space app.
I have done all of that and there is still a major offset. It frames perfectly, both the material edges and the image. But when I go to engrave the image, everything is offset.
