How do I turn on my diode at low power to focus it or frame a job?
Diode lasers often don’t have a red-dot pointer like CO2 lasers do, so it is often useful to enable them at low power for focusing or framing. (Please do NOT do this if you have a CO2 laser, as the beam is invisible and this could blind you or start a fire)
  • In LightBurn, go to Edit > Device Settings, or click here:
  • Turn on the ‘Enable Laser Fire Button’ switch (make it green):
  • Quit LightBurn and re-run it.
  • You will now have two new controls in the Move window. A value to set the power to use for focusing, and a button to turn on & off the laser:
  • Press the button to turn on the laser, and press it again to turn it off. Set the Power value to a very low value that makes the laser just visible enough to see and focus. Too bright and you run the risk of burning the material when your focus is correct.
  • When framing a job, if you hold the Shift key when you click the Frame button, the laser will turn on with the power value specified here.
15W fixed laser diode, setting for cutt
Frame doesn't switch on the Laser and one more question
Another newbie question
How to Focus Diode Laser
Trace the cut boundary with laser on
LightBurn laser wont burn cardboard (Trail)
Not Burning All of Image
Focus ortur 20v laser
Ortur Laser Master 2 20 Watt Focus
Calibrate laser pointer
Configuring a 3018 CNC (or other CNC-based laser) for use with LightBurn
Ortur master 2 framing wont work
Position frame with laser on at 0.25%
Waste board grid
Brand New User - Struggling
Macro docs? how-to?
Frame with lghtburn
Laser not firing up when clicking the show position
Cant do anything....laser fires on command... just don't know how to tell it where and what I want to engrave
PWM frequency for a diode
Low power output for framing and focus
Ortur Laser Master 2 Not Running Focus Test
Cadre light doesnt work
Feature suggestions
Running along working frame
Homing cycle is not enabled in your Grbl settings
How can i see the current engraving area?
Framing with laser in fire mode
Laser not on during frame
No Laser light using frame
New User Problems
Newbie questions Im afraid
Issue with engraving - Poor final result
Framing with light on
Engraving Photos not working as expected
Laser adjust for print area
Lightburn Controls
Laser with Lightbrurn line with GRBL dot
Why does my file frame Super-sized?
No fire mode and laser not burning
Shift frame will not turn laser on while framing
Can i see the laser dot always present?
New user questions - TIA
Do FRAME with laser
"Fire" laser during "Outline"
Move laser to borders
Alignment trick for home made machines
Frame indication
Laser beam view in frame preview. (Laser Diodo)
Lightburn fire button expand TTL
Print and Cut Wizard not working
My laser is not in line with x an y
Laser will not fire consistently
Centering how to turn the light on
Frames Perfect but Image is offset to the left
Laser heads for top left when set up for bottom left
Print and cut does not work
Standby power setting?
Newbie getting started
Laser job starts in corner only I can't move it to position it
Range preview laser
Frame area ? can I get low level beam?
Laser on with frame
Ortur: Boundary LaserGRBL?
Where are the controls and buttons to set the laser?
I need help with a few problems I am having
LightBurn can't communicate with my controller
Undefined feed rate error -Smoothieware Setup
Create a Macro to fire the laser
ORTUR master 2 allumer le laser1
No laser at boundery scan
Frame light occasionally works
Anycubic GRBL - LB Software won't Jog Laser
Laser drifting/ not working
Seeing green light but laser not firing
How to enable Fire button
Laser runs but does not engrave
Ortur LM2 20W Skipping Line Sections
Laser pointer Turned on
"frame" does not turn on the laser / grbl 1.1f
Waste board grid
