Ortur LM2 20W Skipping Line Sections
Is the laser on while it’s doing this part of the path? If you preview the job, do you see the gaps in the preview?
That looks out of focus - if that’s the case, it could just be that the white paper is not getting hot enough to burn (white reflects nearly all the light energy from a visible diode).
Use this to turn on the laser at the lowest power you can see it with (I use 0.25%), then adjust the focus to the finest point you can:
