Hi everyone, i have an Eleksmaker A3 Pro for which i’m currently building an enclosure in my workshop and will incorporate air assist and fume extraction. I have the mana se v3.2 board with the eleksextra board connected for limit switches. Regarding air assist am i right in saying that if pin A3 on the main board controls coolant then the coolant plug on the eleksextra board is controlled via A3? In other words can i simply take a cable from the coolant plug on the eleksextra board to a relay/pump and control using the M8 command?
In a similar fashion can i do the same for the fume extract relay using a vacant 5v output plug on either board and relevant on/off command rather than manually switching? I know it’s no hardship to flick a switch every time i engrave something, just would be nice for it all to happen when i click go and more usefully switch off if i’m not there when it finishes.
Thanks.
