G-Weike Cloud 50w pro 2 rotary with updated Lightburn
Having figured out that Lightburn now uses material thickness for z-focus for the G-Weike Cloud 50W C02 laser instead of the original 17mm - material thickness, how does this now relate to the z-focus height when using the rotary attachment which uses a plastic measuring gauge, and the instructions state “Z-offset (mm) = 86.2 mm − Object/Material Height (mm)”. Do we go back to the old method, or is there a way to use the material thickness to get the rotary surface height? The new fix for material thickness is great, but now confused how to use the rotary.
I never used a Gweike Cloud, but remember reading in their manual that you always had to do some math when setting the Z height.
Can’t you just focus on the rotary object’s surface and leave Material Height at 0?
@BillieRuben Wrote this tips and thricks post for the Gweike Cloud, I’m not sure if that still applies to version 2.2.01.
Unfortunately, the G-Weike cloud has no ‘focus’ as such, its just a stepper controlled head, and you can type in how many mm from the homed 0 point. For perfect focus on the honeycomb, it needs to be set at 17mm from origin. The latest version of lightburn takes care of that by just entering the material thickness. Unfortunately, the complexity comes with the rotary as you remove the honeycomb, which is the reference point, and G-Weike give you the formula and a plastic measuring tool, but that does not relate to the way lightburn now uses material thickness to move the laser head… If it do the calculation, and move the laser head the required amount from the homing position as per G-Weike instructions, will the new Lightburn over-write this with material thickness setting? I can’t find any Lightburn guidance either way.
I had a similar issue but not with the rotary. I wanted to engrave an object that was 50 mm thick, which exceeds the Z. I placed a piece of sheet metal under the laser for my platform. I measured the distance from the surface of the honeycomb to the sheet metal surface below. I subtracted this number from the workpiece height of 50 mm. I ended up shimming the bottom metal to where the difference was 5 mm and set my material height to 5 mm. Then remove the honeycomb and tray and engage the interlock bypass switch so the machine will run with the tray removed. Using the camera overlay and frame the boundary I was able to position the workpiece correctly and it worked. Hope this makes sense.
Makes perfect sense, probably the method I’d have started with in that case. Thanks Charlie.
Anyone have a robust way to measure the physical height above the honeycomb of the laser that can be compared with the value in lightburn to check how the 2 correlate? Is the 17mm (focus for material thickness = 0) the distance between the nozzle tip and the honeycomb? I’m trying to work out physically where the focus point is from a reference point on the laser head.
Run a ramp test between two known measurements to get the exact focus distance.
This is a somewhat overenthusiastic fixture, but you can scorch any flat surface:
