Hi ,
Trying to set up my galvo , I am unable to see a frame with previewing the engraving . When I switched back to Ezcad it’s there, I have check over the setting they all seem to correct , where else or what else can I check , also the red dot is off when I am working with lightburn, but is on with Ezcad .
You don’t have a red dot port enabled in LightBurn. On almost every machine I’ve seen without that specified, you set it to port 8.
Hi Oz, are you refering to the start marking ? I the first photo Start marking is set to 15 and pulse is checked . I have tried to switch the port to 8 but still no successful.
No, this one:
Set that to port 8.
Thanks ! it took a second, it was actually port 4 , but none the less its working . Thanks !
