So i was having this same issue. I followed the steps provided by re importing the markcfg7 file and it seemed to fix the issue for a while. But now it has started doing the same thing again. Where the power level seems to get " stuck" on the last power level used. From an engraving pass to a cleaning pass. Then when i restart the job its stuck on the last power level from the cleaning pass. Example: Engraving at 95%, then cleaning layer starts and is set to 40% but seems to still be at 95%. Then when i cycle power on the laser, turn off the out put on the engraving layer to just do the cleaning layer. Once that job is done, i turn the engraving layer back on, start the job and it seems like the power is till at 40% when it should be at 95%. Im unsure what to do at this point. Is there any other update regarding this issue?
