I am using for years now Lightburn for home made laser machine with GRBL.
Now I want to use it aso for a plasma cutter I build myself also with GRBL. This machines works great but I want start using the Lightburn software because all of its advantages. It has kerf, pierce delay, lead-in. The only problem I have is that when a path starts (pierce delay 1 sec) the torch starts and after 1 second the movement starts but at exact that moment the system (very shortly) switches off the torch.
Gcode beginning of a path:
M5
G0 X177.534Y109.266
M3
G1 F100 S1
G4 P1
G1 S0
G0
M5
; Layer C00
M3
G1 X177.423Y109.03S1F1400
If I remove the lines with code:
G1 S0
G0
M5
everything works fine. If one of these lines remain the problem also remains.
How can i setup Lightburn that these codelines are not generated.
Ofcourse I can use an editor to remove the lines and use another program to execute the code, but my preference would be to control everything within Lightburn.
Maybe a specific PLasmacutter switch??
Have you reviewed @bLouChip’s Topic on this? If not, worth review. He covers his findings on optimizing LightBurn for plasma cutting and employs the new custom g-code generator.
Everything done! Works great! I could adapt the gcode to exact what I needed. I can design now on Lightburn and run immediately on my plasma cutter without any problem.
This Custom Gcode is a great addition.
Thanks also for the quick responses.
