Just updated the software and was pleased to see that you can enable the laser while framing.
Went to device settings:
I don’t see the “laser fire button” in the laser window and the laser does not fire when I press “Frame”. I restarted both machine and software and still no change.
The Fire button itself will appear in the Move window. Press the Fire button and raise power level up until a dot is visible. Framing will use the same power as the Fire button.
