Are there ideal settings for laser engraving into wood?
Not without testing on your exact system. But there are some starting points…
This is worth review, and you should test these settings on scrap, adjust for your material and laser output.
Yes, and you can use the techniques suggested in this tutorial to find out what they are for your laser…
Will the $$ setting come into play when trying to get everything setup? Is there an ideal setting for that to make sure the machine is working properly?
Ah, yes. Have a read of this: Common Grbl Setups - LightBurn Software Documentation
The entire set of documentation, also worth review, is there to assist you in learning about LightBurn.
