Grayscale images explained
I got the image into gimp and it indexed 85 tones (the 16 colours must be the primaries), so I transferred the palette over to the Land-rover image and it looked OK on screen…but have to wait to laser as I ran out of daytime. Also they imported at different dimms when reimported from gimp without alterations being made.
Fundamentally this should not be a 100% success because ai builds an image from the ground up specially for purpose, whereas the photo has all the attributes that are expected…Oil and Water!
I think I understand what you are trying to do.
I imagine that all images need to be at the Sam bit depth before you try and do anything.
Apply the color palette of the lion to replace the color palette of a different image and see how that converts to grayscale in LB.
I would be more inclined to convert the images to grayscale and apply the gray pallet of the lion to your new image. That way you aren’t trying to convert a limited color pallet to a huge color pallet. I don’t know if it would make any difference other than dealing with a lot of RGB data, it might do better with the only the black channel.??
Interesting workflow.
The other thing is the sharpness, contrast, etc. of the lion. Not just the color pallet.
I have tried the color pallet thing a reallllllll long time ago (photoshop 3) it didn’t work out very well.
I think your rabbit hole just got deeper than mine.:grinning_face:.
Try this workflow.
This lion is a perfect example of Ultra-Detailed HDR Wildlife style. It’s not just a photo - it’s pushed to maximum texture, maximum sharpness, and maximum jungle color.
Here’s the exact GIMP workflow to get that look and then apply it to any other image:
What makes this lion style?
  1. Fur is razor sharp - every hair separate
  2. Wet, high-contrast face - drool, teeth, nose are HDR lit
  3. Jungle is saturated but dark - deep greens behind, bright greens around paws
  4. Aggressive micro-contrast - looks 3D, like it’s popping out
GIMP 2.10 / 3.0 Workflow - Step by Step
Do this on your lion first to save it as a Style Preset:
Step 1 - Prep for detail
  • Image > Scale Image: 4500px longest side, 300ppi, Interpolation: NoHalo
  • Layer > Duplicate Layer (keep original safe)
  • Filters > Enhance > Wavelet Decompose: Set to 5 scales, click OK. You’ll get 5 detail layers. Slightly increase opacity of Scale 1 and 2 to 120%. This is how you get that fur texture.
Step 2 - Get the HDR sharpness (the most important part)
  • On the top layer: Filters > Enhance > Unsharp Mask:
    Radius: 3.0, Amount: 0.70, Threshold: 0 - this is for the big fur
  • Layer > Duplicate Layer again
  • Filters > Enhance > High Pass: Radius 10. Set layer mode to Overlay and Opacity to 35%
  • Filters > Enhance > Sharpen (Unsharp Mask) again: Radius 0.8, Amount 1.2 - this sharpens just the eyes/teeth/drool
Step 3 - Jungle color like this image
  • Colors > Shadows-Highlights: Shadows +40, Highlights -30, White point 2.0 - this lifts the dark fur but keeps jungle dark
  • Colors > Curves: On Green channel, pull middle up slightly. On Blue channel, pull shadows up slightly for that humid jungle look
  • Colors > Hue-Saturation: Greens Saturation +60, Yellows +20
  • Colors > Vibrance: Vibrance +55, Saturation +15
Step 4 - Wet look
  • Tools > Dodge/Burn Tool: Dodge (brighten) the teeth, claws, drool trails, and nose highlight. Burn (darken) around the mouth
  • Filters > Light and Shadow > Lens Flare or paint white dots on drool with small hard brush at 80% opacity
How to ALLOY / Apply This Style to a Different Image
Method 1 - The 1-Click way (Best):
You need the free G’MIC plugin for GIMP.
  1. On your finished lion, in GIMP: Filters > G’MIC > Colors > Transfer Colors [From Image] - this saves the color look
    OR to save a LUT: **Filters > G’MIC > Colors > Color Preset **[Save]
  2. Open your other color image:
    Filters > G’MIC > Details > Freaky Details: Scale 0.8, Sharpness 1.5, Vibrancy 1.2 - instantly gets that fur pop
    Filters > G’MIC > Details > Sharpen : 3.0
    Then Colors > Map > Sample Colorize or Filters > G’MIC > Colors > Apply External LUT - select the lion LUT you saved[Texture]
Method 2 - No Plugin, Pure GIMP:
  1. Open both images. On your lion image: Colors > Map > Sample Colorize > click Get Sample Colors from image
  2. Open your target image, then Colors > Map > Sample Colorize and it will apply the lion’s palette
  3. Then manually apply: Filters > Enhance > Unsharp Mask (3.0 / 0.70) + Colors > Levels (move middle gray to 0.9)
Final export like we did before:
  • Image > Crop to Content to remove outside
  • Filters > Enhance > Unsharp Mask: Radius 2.0, Amount 0.6
  • File > Export As > PNG, check Save resolution 300dpi
More fun with the lion.
Full color
8 bit. This is a little brighter. I guess it is because it has a smaller color pallet. A lot of detail missing.
Bit depth…Bingo!, and a few other penny’s dropped along with it. Workflow/Pipeline, both digital and Cognitive, and ultimately the data you start with…Raw and IR for high contrast. It’s still going to be a ways off from what ai builds..but maybe enough to create/process something good.
I often forget to say G’Mic as I regard it as part and parcel of gimp, but that’s the starting point with Raw data, then into gimp.
I recognise a lot of the tool names in the workflow/pipeline you gave but many are new to me.
Thanks Jay.
Thank META, I just asked it a question. I asked it to give a GIMP work flow to achieve the results of the lion. I don’t have access to what I originally asked for, but that was basically what I asked for.
A small test on slate turned out OK but a bit dark even though I dropped the gamma to .750 and added quite a bit of sharpness. There is loads of detail in the Ai image so I’ll do it again quite a bit larger which will/should bring out the detail and brightness won’t be needed…or perhaps just a touch of ‘Brightness’.
Not good light when taking this pic but it is good and is way more photo-like than the previous version.
That one didn’t have any script added. I told it to add the mist, and then told it to add the waterfall.
Which image did you use the 32bit or the 8 bit?
They look way better than my diode has done with slate, but I really haven’t tried state but one time. I need to do a speed/power test. I have only done line art images.
I am impressed.
What are your image settings?
After I imported to LB I was adjusting power/speed and forgot which was 8 and 32bit…but does it matter because they both load to LB at 8bit and I made no alterations whatsoever except for LB: Gamma 0.750, Dpi 230.9, Enhanse radius 2, Amount 300, Greyscale. Power 14.5, Speed 4000mm/m…20w diode.
After completing I immediately thought to increase brightness by a touch…maybe this…maybe that! But looking closer I could see the potential was there to bring out the detail by enlargement.
I thought, if it’s in the original and the original is bigger, then don’t worry about the sliders…just print it like it’s sposed to be…trust the ai. It’s a darker moodier picture than the previous lion anyway…but really good quality, like almost photo…except for the lion paws that don’t have the rocks under them anymore.
If the ai graphics is tracking your progress then there’s a chance it improves on each iteration and like ai chat it can also forget things it did or said previously.
Very nice Ferg
GPT is working well for you.
I’m going to have to try this. My mind has been working in a positive image world, now I have to start thinking negative.
Another rabbit hole to explore.
I like that Ferg, it shows that there is a lot more detail in the image that you can’t see in the color pic.
It even created some on its own. There is a stream added on the right hand side of the lion. The was some other things added to the bottom of the image as well. It even changed the waterfall.
Compare the two, and I bet you will find some other changes as well.
That’s the part that is most frustrating about Ai, it tends to to enjoy screwing with an image. You have to be so specific with you instructions.
Just like this lion. I asked for some minor changes to original square image, and got the basic image and then it asked me if I would like to add mist to the image. Sounds good to me. Then it asked if I wanted to add the waterfalls in the background, again, sounds good to me.
That is how this image was created from the over sharpened, over saturated square lion you see way up this thread.
YOU CANT SEE THE FOREST FOR THE TREES :joy:
What you ask Ai to do, because I like the “find edges” look. I did something like that way up in the thread, but it wasn’t as good as this.
When you try it, lift the brightness also. Bigger version just started and I also brightened to 4, only an inch or so into it but way more detail…Actually maybe a little less on the brightness!!
Also, an observation tells me, in image adjust look at plants on left side and adjust till small plant leafs are brighter than dark areas on of big branches/deep shadows etc…but don’t blow out the highlights in the bright areas.
Hmm.. Maybe should have followed my gut feeling on just letting it be as Ai intended.
This one looks better in this pick than on the cutting deck. Lots of Clipping in greys and blacks and detail lost at the waterfall.
I think you are right not enough differentiation in the mid tones and shadows. A little too flat.
Ferg
This an actual engrave
That’s very well balanced all round and the material isn’t fighting it.
I like it. My brother and sister-in-law have a really old log cabin on their property. It’s about the same size.
This great. A good greeting card image. Very welcoming image, “Come on in and sit by the fire”.
