Great, now I have a much better view on interpolation. Would it be more convenient to import a 10" image to lightburn and then post the lbrn file, which could then be exported by me to gimp and re-ordered for resolution and print size.
I see the saving a LB file with the 10” image what is the pixel size of the image?.
I don’t understand the “post the file” where are you going to post the .lbrn file?
Then the last part importing the .lbrn file into GIMP.
Question is confusing. What is it that you are trying to achieve?
Are you trying to get a 10” at screen resolution 72 DPI ?
I have found it is a lot easier to get images into LB, but trying to get things out is a lot more difficult. ( See attached file)
It may confuse you even more.
Lion size test.lbrn2 (5.0 MB)
One thing you can do is select any or part of your file and export to a .svg file, just another way to get something out of LB.
Well, if the image is imported to LB you can see all its details such as LB screen size, Px dimensions, image quality, and how it fits within what material space you have available etc.
Right Click on image on Lightburn screen > ‘Save as’ (To files/folders) > Right click on the file - ‘Open with’ (eg-Gimp) > Set resolution + Print size + image adjustment if required > Export to computer > Import to LB.
I thought you were importing the entire LB file into Gimp. My error in interpretation.
It is amazing how many ways there are to get around software limitations, just as long as you can remember the whole process and get the results each time.
I just keep repeating from memory (best I can) until my brain surrenders because it’s run out of alternatives…works every time, or is that every 100th time!
I just realized something sort of wrong I’m my think of how LB handles grayscale in the adjustment tool
open the image and select display. it looks good
set the Line interval DPI to 10. this is what i realized
the DPI which changed the image on the right to a very pixelated image and different pixel size
click OK.
the screen image doesn’t look any different and resizing it on screen doesn’t change any thing, but display this image. The image reflects the 10 lines per inch. that is LPI not DPI.
this is what is confusing me now.
I don’t see where (at least on screen) you can output the pixelated image.
In adjustments we set the DPI which is actually LPI and the display shows the Pixelated image and size change, but doesn’t change it on screen.
In cut/layers the DPI is set to 10 for grayscale which we set in the Adjustment tool. Now if we actually wanted to output the pixelated image you would think that would should change the LPI back to 254. and that would produce a pixelated output. look at the image in display and it looks like the original and not pixelated. I think this is a bug
I believe the grayscale image is cached (so that you can make changes again) with the underlying adjusted/processed image for the output or further processing (like tracing) in LightBurn.
Reading the doc the changes are applied to the Layers:
I understand that but my question is.
What good is the displayed image on there right side.
When you change DPI real LPI in the cutLayers.
You see see a changed Pixel size and a pixelated Image,
When you click Ok.
The image should reflect the new size of the image.
Currently the previewed (resized and Image) has absolutely no bearing on anything.
On screen it is still the same image with the LPI shown in cut/layers.
Changing the LPI/DPI should be Dots Per Inch not Lines Per Inch. that should only be addressed in the CutLayers not in adjust image.
Resize and all the other controls of an image in Image adjustments.
Power, Lins per inch, etc. in cut Layers.
I consider that a Bug, Like I said show me a displayed image in the adjust image tool of something that is totally irrelevant is useless.
Sorry I didn’t answer your question. I missed it.
The biggest problem with Ai generated images is that you don’t have much control over what or how it interprets your request. I wish it wasn’t that way.
I have had it screw up so many times I can’t count them. Sometimes it comes back with some really creative mistakes that causes me to change direction, but usually gives me something I didn’t ask for.
I have asked just to add clouds to the sky in a perfect image and when it added the sky it decided it need change the rest of the image Very Frustrating.
Glad you joined the trip down this rabbit hole.
Can I ask what was your use case for seeing lpi/doing alternations in Image adjust.
I have always regarded Cuts/layers, Preview, and Image adjust as being different perspectives on the same thing with each having its own purpose while keeping most of the relevant info observable in all three.
The Lpi/Dpi is primarily for Dot spacing on the x axis and Lpi for the scan line distance/gap on y axis, while having no effect on pixel dimensions.
Although I have no experience with ai Image prompts I was working these past few days on Image quality and histograms. The ai search engine at one point put forward an example of prompts that were linguisticly quite dissimilar to how I would have asked for the same thing. This is a very interesting topic and worth researching.
The rules for ai/human conversation are quite time consuming and smewhat perplexing, It can take three days to find a method of doing something that is designed to save three days of work by other means.
That is called Net Sum Zero.
Yeah, and it turns out to be a non reusable/transferable method…Ahrrrrg!!
Jay
I’ve had an idea, would it be possible for your Ai Image software to list all the colour values from either of the two lion images. I have both here so either one is OK.
I’m going to do the same thing with gimp and LB, I think it may be helpful to cross compare.
This is just the exact problem I have with the DPI moniker in LB.
In both instances adjust image and cut/layers it is defined as DPI, but I actual (and it does say above the DPI box) it talks about lines per inch. Go figure.
In the adjust adjust images the DPI has no bearing on pixels it adjusts the LINES PER INCH. Then that reflects the same setting in cut/layers.
I contacted LB about it and they told me to put it in the suggestions, because the programmer deal with that.
So go to the suggestions and add a vote to my request.
It is confusing.
Are you wanting a color or b/w histogram?
lB doesn’t do histograms color or b/w.
Which image?
Any script I get to work, I always do a copy and put that is a file and label it so I can use it on another image I would like to repeat, or at least give me a starting point.
I have taken an image and pasted it into the dialog window and asked Ai what I needed to as it to create an image like it. Ai comes back with a really long explanation of the process.
It is always a good starting point. Salve a day in your 3 day process.
B/W histograms would be great for either the lion with sky behind or lion with jungle behind.
If you could load 1 lion Image to lbdev file and same image as png uploaded from your computer.
The thing is to have as few steps as possible to exclude any variation.
Could you also ask the Ai for a 'Color values list, so we not only have the qty of pixels per Tone in the Histogram but also a list of each Tonal #Value (the palette).
Apply no changes Post Ai rendering and note (if any) File type changes and Size throughout.
LB has no Histogram (it doesnt need one) but it must apply a value…That value equates to the Palette.
A 4" (100mm Sq) Image will save material and allow room for many side by side comparisons If need be, But I think there will be a need because I did a Histogram swap earlier from the lion to a land-rover atv and did not get the result I wanted. I did three further LB image adjusts but it’s just not the same. It’s only information/data so there has to be a way to transfer Style A to B.
All I know about Dpi/Lpi is that they adjust relative to each other but I regard that as a mathematical/mechanical necessity. I think I have encountered a slight variation in dpi/lpi values between Cuts/layers and Image adjust windows but then again that might have been the incremental change settings. Would it help to manually input the values?
I would imagine that if there were an issue to find, it would have been well noted by the LB users who are dependant on accuracy. Have you checked the topics history.
Color Value File - Square Lion Jungle - 16 dominant colors
HEX, RGB, Percentage approx
- #1B190B RGB(27,25,11)
- #58572D RGB(88,87,45)
- #9E9865 RGB(158,152,101)
- #63684D RGB(99,104,77)
- #4D341C RGB(77,52,28)
- #364A1F RGB(54,74,31)
- #937252 RGB(147,114,82)
- #728B5B RGB(114,139,91)
- #E5CEA4 RGB(229,206,164)
- #D0A16D RGB(208,161,109)
- #D6B28F RGB(214,178,143)
- #916332 RGB(145,99,50)
- #A5A88C RGB(165,168,140)
- #6E8B2F RGB(110,139,47)
- #ECE0CE RGB(236,224,206)
- #B4C994 RGB(180,201,148)
Roly LaserMATIC Mk2_08292023b.lbdev (7.4 KB)
Not sure what you are referring to transfer style A to style B. In LB or Meta? META copy and paste instructions, and hope for the best. LB adjust image create a preset. is that what you are refering to?
no. There is no way to adjust the X x Y pixel size of an image in LB. That is why I said vote for my suggestion to add that feature.
There are a lot of suggestions sent to LB. These are wish list items. LB is accurate in the things it does, but lacks so many tool that people wish they would address. Like Fonts, it does not support font families. There is one helvetica, and you can apply bold, italic , etc. but my helvetica has 10 different fonts and LB doesn’t let me access them.
LB is like a limited illustrator program, and for $60 it does an awful lot.
You do know that you can use META for free and get some of this info your self.
Meta, I’ll check that out, thanks. This ai thing is quite new to me.. beyond knowing it’s there, but I’ve been chatting with Brave browser and it’s great once you keep an eye out for what it forgets and some tunnel vision it suffers from. It only does search as far as I’ve seen but it told me about Chat-gpt and other Ai image creation options with some laser engraving workflow info.
This workflow to manually create the ai quality image is a long workflow to learn and Brave said it wouldn’t be worth the effort given the numbers of apps etc that are available and also the often mentioned “Garbage in = garbage out” if the image doesnt have the qualities to begin with, but it is good learning all the same.
While I thought the idea is a non-starter, I have one last lead to follow to see if ‘local contrast’ is of any help as palettes etc aren’t enough info for real image improvement…other than that I’m opting for an ai imaging package..maybe!
If you change the size of the image in LB, You change the size of the pixel but that’s no good if you need a set pixel dimensions and image size without a lot of calculating. For both adjustment options you need Gimp..or perhaps other and it’s pretty easy in gimp>scale image.
I agree with the fact, if you are going to deal with images you need a graphics software to do all that image work. LB is meant to be a vector based software that allows some limited image manipulation.
I am glad the LB allows grayscale images, and can handle (although limited) them. What I am doing is pushing the boundary of LB way beyond what they envision. That’s where the fun is.
I don’t do craft shows, so if I make something useful it is for me or a gift for someone else.
