This is defaults, you might have something else going on
Let me ask though, ONLY happens when both motors start moving in vectors, curves?
Wonders if it could also be current draw?
Got to compare all values if i am honest because there are on $$ multiple variables that could play into the problem
IF you cant figure it out, try recording a small video of it, and upload to youtube or soemthing. At times audio/video gives a ton of insights on what might be going on.
also isolate the steppers
As in, unplug X motor, run
swap Y motor, run
Do they suond the same and move the same if isolated?
So I did ALOT of playing with firmware and got most things working. Acceleration is perfect, calibration is perfect. Added a 5v relay to fire the plasma. Thanks for all the help. Now I have one thing stopping me.
When the dwell time is turned on in lightburn it fires the plasma and dwells properly. But then it very quickly turns the relay of and on ( few milliseconds in the open state) and then rapidly closes to fire the plasma for the cut after the dwell. This quick open and close of the relay causes the plasma cutter to not fire on the second firing of the relay. I see this is because there is a g4 p.6 for dwell then a m4 and m3 to fire the plasma. I’d like to dwell and then just continue the cut without rapidly opening and then reclosing the relay. How can I do this within lightburn so that I don’t have to manually edit the post processed g code.
The relay is on at 5v. I have tried it at lower volts and it does not close at anything under 5v. I do not know what the $30 and $31 are as the plasma cutter is at my friend’s shop. I will go sometime this week and report back.
@TonyDovaloni , as of V1.5, LB now has a better method for CNC plasma table process. The dwell behavior you are seeing is normal behavior for laser process. It’s simply not applicable to plasma process for the reason you cited. Rather, you should create your own Custom GCode device profile and you can add to it your own gcode stmts for key events in the plasma process and custom for your CNC plasma table, including a pierce delay. I have an example of using it in the following link. My example even uses a floating torch probe cycle to find the surface prior to each shape cut. Enjoy.
Last night, before going to sleep, I did a search and collected some links, small world, some of which are from bLouChip (a success story), have a read very well explained.
Adding to your list, if OP or anyone is looking for a Lightburn - Sheetcam workflow combination for plasma process, especially if they have multiple CNC process tables or as in my case, a single CNC table runs processes of laser, plasma, and milling…
then consider grbl/HAL or LinuxCNC as controllers. LB supports both in laser process. And both controllers are EMI hardened and facilitate further EMI mitigation with signal and control wiring.
For plasma process, both have an integrated THC capability. In the case of grbl/HAL, follow the links on its page.
In the case of LinuxCNC, see this post for 3 components (sw + 2 hw).
Loaded your .lbdev file and it controls our machine. But before I do any testing I want to make sure we do NOT have THC enabled as we do not have a probe or z axis. Any recommendations on how to proceed?
Also thanks everyone for all the input. This place is a wealth of knowledge
Since you don’t have a THC nor a Z axis, all you’re going to need in the Tool On device action is:
;tool on
;|ABS| (macro wasn’t available in last beta I used)
;adjust this code for G91 or G90 mode G0 Z3.7 (move to pierce height)
M3 S1000 (fire torch either via Spindle Enable or SPWM)
G4 P0.800 (hard coded, dwell var not available here) G1 Z1.5 F1000 (move to cut height)
G1 F{speed}
;|RESTORE| (same as ABS I presume)
;end tool on
In LB, use menu Edit->Device Settings, Custom GCode tab
to edit the device actions. See the doc for more details and edit macros and choices.
So I tried the above code. The plasma cutter not run a job when I draw a simple circle. But the machine will job once and the console says stream started and then never ends the stream. I change the device to a regular grbl profile and not the experimental device and everything goes back to operating but I then still have the issue firing the plasma. Any suggestions?
please export your Custom GCode device and post the resulting .lbdev file, and post your .lbrn2 file with the shape(s) that don’t cut. I’ll take a look at it.
please post your LB generated gcode file also, Save Gcode button in Laser window to create the file.
as an example, here are the files I just used to generate valid CNC plasma gcode for a job cutting 1 simple square shape.
I forgot you don’t have a Z axis, so when I “corrected” the code snippet above I broke it for you, I was thinking you ‘only’ lacked the THC and floating torch mount. Disregard any “G0 Z…” motion stmts.
I believe your CNC controller is hanging or throwing an error msg re. the “G0 Z20” stmts in the .gc file that you posted. Again, you don’t have a Z axis, so don’t produce Z axis code. Check each of the actions in the device profile for Custom GCode and adjust those action stmts to remove Z axis motion.
you are also producing gcode in ‘relative’ G91 motion mode. That can be more complicated and dangerous since Custom GCode device actions have mostly hard coded stmts, although the doc mentions the ability to flip between absolute and relative motion with some builtin macros. During the beta, when I tried to use these macros, they didn’t seem to be implemented yet and I’m not sure if they are there now.
Thanks for the info. I will try getting rid of all of the z movements as suggested and I will switch to absolute mode rather than relative. My only remaining question is why when I jog the x or y does it jog but then hang up and never complete the action from a software side which in turn won’t let me send any other commands?
Also thank you for all of the help. I’m a engineer by day but I do manufacturing…the software side of things is basically magic, so I really appreciate all the help.
very important stuff, especially when operating in absolute mode. In current position mode, you can “cheat the system”, jogging works most of the time without a complete and thorough LB / grbl synchronous configuration. Not recommended to cheat the system, purposely or unknowingly.
