i lost GRBLE in the lightburn program , I have low power to the lazer and need to get grble back in the system . I can see the lazer firering but no results for now i am in the free trial just wondering if I should delete the trial purchase new and download again.
A few checks to do
a) Edit → Settings are you in mm/min or mm/sec
b) on the laser panel - click the Devices
Double click your device. Is your device the GRBL one, or GRBL LPC or M3
c) Edit _> device settings
can you take a screenshot?
d) Can you take a full screenshot of your lightburn with your project open showing layers?
settings= mm/min no value in box, I have no grble I accidently deleted it im trying to get it back
Please don’t multiple post… it takes time to sort these out.
Grbl is the instructions sent to the controller, you can’t lose it…
Might be good if you clarified what is happening and how you set it up.
the lazer is working but has no power also grbl does not show in the devise as far as setting up i have been following youtub anything else i can find
Maybe check these guides:
These should help setting up your Sculpfun laser.
