I have a Chinese 6040 laser that was built with an M2 Nano board which Still works fine with it but I wanted to use Lightburn so I bought a Cloudray HQPI controller card. It is a plug in swap from the M2 Nano to the Cloudray implementation of a GRBL controller card that also has laser PSU power control. I have not connected the PWM power control yet as there are issues in getting basic operations with Lightburn 1.7.08 to function. I have the machine on windows 7 Ultimate because I still have customers’ work to handle and I can then just swap the M2 Nano back in to keep the doors open.
I can’t move to a higher windows because I need Windows 7 to communicate with the M2 nano card. My issue is that while Lightburn 1.7.08 can communicate with the HQPI card for homing and using the frame button to draw a square.
If I click start after doing a frame, the box I drew burns but, in the opposite direction to the frame direction. It burns on the line that frame outlined. When I hit home and just hit start after the homing, the same square burns in the anticlockwise direction, as it did after frame, but; it burns from the wrong starting point and is not on top of the burn that was done after the frame button. Here’s some numbers.
I drew a 30x30 square in lightburn with the top left corner of the square on X20, Y20. The frame button causes the head to trace, clockwise from 20,20 to 50,20, then 50,50, then 20,50 and finally back to 20,20. Start causes the head to go to 50,20 then 20,20, then , 20,50, then 50,50 and back to 50,20. so the burn is anti clockwise. When the home button is pressed, it homes to 0,0 absolute coordinates in the top left corner (4th quadrant), then start is pressed, the head moves to 20,20, then burns to -10,20 then -10, 50, then 20, 50 and back to 20,20.
If I just do a X10, the head moves to the right as expected. Y10 moves the head down, also as expected. I’m at a loss as to what is happening here. As I understand absolute coordinates, means that everything is referenced to 0,0 which it actually is doing. it’s just that the burn appears to be starting 30 to the left of where it should start when Start has been selected after homing. It behaves differently after frame is used. I really expected the burn action to be moving in the same direction as the frame action, clockwise. It’s not flipped axies because when commanded to move in a positive direction,it does move the head in the correct direction.
I know this has been long winded but i don’t know how to make it shorter and i hope it makes sense. I would love to try this on a windows 10 machine with current software but i need to be able to support my customers while I wrangle this issue. I’ve been at it for 3 days now with no progress.
All of my artwork from 2012 to present has been done on Corel so there’s a LOT of artwork. I will need to be able to just save it to a format Lightburn can read but if its going to not be able to handle the drawing, I’m stuck with the M2 Nano and Win7. The cutting appears to think that its in 3rd quadrant while frame is behaving like its in 4th quadrant.
My microswitches are in the top left corner of the machine. I hope someone that is familiar with G-code can offer some assistance because I suspect it might be something to do with that.
Kind regards Peter.
