parsec
(FerAS)
November 28, 2024, 8:02pm
42
Check focus and if your laser lens are clean.
Both checked. Still not enough power to leave a mark!. Weird!
moors7
(Jordy Moors)
November 29, 2024, 9:03am
45
You need to systematically go through the GRBL settings and reconfigure them for your machine. There are several guides that can walk you through the process. Hereβs a quick cheat-sheet I found that might be able to help:
Here is the full explanation:
## Getting Started
First, connect to Grbl using the serial terminal of your choice.
Set the baud rate to **115200** as 8-N-1 (8-bits, no parity, and 1-stop bit.)
Once connected
you should get the Grbl-prompt, which looks like this:
Grbl 1.1d ['$' for help]
Type $ and press enter to have Grbl print a help message. You should not see any local echo of the $ and enter. Grbl should respond with:
[HLP:$$ $# $G $I $N $x=val $Nx=line $J=line $SLP $C $X $H ~ ! ? ctrl-x]
The β$β-commands are Grbl system commands used to tweak the settings, view or change Grbl's states and running modes, and start a homing cycle. The last four **non**-'$' commands are realtime control commands that can be sent at anytime, no matter what Grbl is doing. These either immediately change Grbl's running behavior or immediately print a report of the important realtime data like current position (aka DRO).
This file has been truncated. show original
And here the specific lightburn docs on the topic:
system
(system)
Closed
December 29, 2024, 9:04am
46
