juansierra
(Juan A Sierra)
June 29, 2019, 3:36am
1
I’m having a heck of time engraving objects to an specific size, if I create a circle 1in in diameter when I engrave it , it turn out to be 1.5 in, any help
This should help (click the link to jump to the topic):
That’s fairly easy, though it depends on whether your controller uses “step size” or “steps per mm”. They’re used for the same thing, but the calculation is a little different.
80 steps per mm is 1/80mm per step.
If you tell the machine to make a cut that is 100mm across, but it comes out to 150mm, your ratio is 150/100, or 1.5.
You would divide your steps/mm by that number, or multiply your step length by that number, to get the correct answer.
So, if your machine used 80 steps/mm, you woul…
juansierra
(Juan A Sierra)
June 29, 2019, 3:46am
3
Thank you, will work on it in the morning.
system
(system)
Closed
July 13, 2019, 3:46am
4
