It acted like before, it would go to 220,0 and then try to go to beyond the y axis. Once I changed the soft limits setting back it goes to 220,290, hits the switches, and throws the error code. But if clicking go to origin takes it back to 0,0 and will let me use it exactly how the screen shows in lightburn it’s an error I can live with.
My current power supply is a 12v. So I could find a 12v laser module from Amazon like the one below that will work with 12v, adapt it to fit then it should work fine without any adjustment to the GRBL code?
https://www.amazon.com/Optical-Engraving-Cutting-Protection-Engraver/dp/B09KWX65XY/ref=sr_1_13?crid=3IBL20Q39F9BL&keywords=laser%2Bmodule&qid=1643727327&sprefix=laser%2Bmodule%2Caps%2C159&sr=8-13&th=1
