You have mounted it your diode allmost like I have, how did you connect it to your controller? And what laser(tube) settings do you use?
if you burn this logo with your co2 does it come out correct?
yes if i burn this with co2 it comes great just the diode behaving weird while engraving the diode comes with a adaptor the green color board where i have given a dc input and ttl and ground wire from the ruida controller cn6 port
This works for me but I have seen that it does not work like desired for what ever reason. See this thread: Adding a diode to Ruida machine
There Someone got it working using pin 2 and 5 which I have not tried yet
Tried this also not working same problem…
tried what exactly and how are your laser machine settings?
Did you get your diode working with Co2 machine?
