I am brand new to lasers. I have a Opt PLH3D laser attached to my CNC OpenBuilds Lead 1010 blackbox. I have the connected my laser to lightburn manually, but my laser will not move using home or direction buttons. It will fire if i press the fire button. I have tried offsetting my workspace because i think I have a negative workspace, not sure if Idid this correctly. I have been trying to figure this out for a couple of weeks and have had no luck. Any suggestion or solutions are appreciated.
Waiting for connection…
Grbl 1.1g [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
error:9
G-code locked out during alarm or jog state.
[MSG:Caution: Unlocked]
ok
[VER:1.1g.20181112:LEADMACHINE1010LASER]
[OPT:V,15,128]
Target buffer size found
ok
error:9
ok
[OPT:V,15,128]
ok
<Idle|WPos:-271.050,-175.344,348.925|FS:0,0|WCO:271.050,175.344,-348.925>
ok
Starting stream
[MSG:Pgm End]
Stream completed in 0:00
<Idle|WPos:-271.050,-165.344,348.925|FS:0,0|WCO:271.050,175.344,-348.925>
ok
Starting stream
[MSG:Pgm End]
ok
Starting stream
[MSG:Pgm End]
<Idle|WPos:-261.050,-175.344,348.925|FS:0,0|WCO:271.050,175.344,-348.925>
ok
Starting stream
[MSG:Pgm End]
<Idle|WPos:-251.050,-175.344,348.925|FS:0,0|WCO:271.050,175.344,-348.925>
ok
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Stream completed in 0:04
ok
ok
ok
ok
ok
$0=10
$1=255
$2=0
$3=4
$4=1
$5=0
$6=0
$10=0
$11=0.020
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=3
$24=100.000
$25=1000.000
$26=250
$27=5.000
$30=1000
$31=0
$32=1
$100=199.100
$101=199.100
$102=199.100
$110=4000.000
$111=4000.000
$112=4000.000
$120=700.000
$121=700.000
$122=700.000
$130=810.000
$131=730.000
$132=90.000
ok
$0=10
$1=255
$2=0
$3=4
$4=1
$5=0
$6=0
$10=0
$11=0.020
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=3
$24=100.000
$25=1000.000
$26=250
$27=5.000
$30=1000
$31=0
$32=1
$100=199.100
$101=199.100
$102=199.100
$110=4000.000
$111=4000.000
$112=4000.000
$120=700.000
$121=700.000
$122=700.000
$130=810.000
$131=730.000
$132=90.000
ok
$0=10
$1=255
$2=0
$3=4
$4=1
$5=0
$6=0
$10=0
$11=0.020
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=3
$24=100.000
$25=1000.000
$26=250
$27=5.000
$30=1000
$31=0
$32=1
$100=199.100
$101=199.100
$102=199.100
$110=4000.000
$111=4000.000
$112=4000.000
$120=700.000
$121=700.000
$122=700.000
$130=810.000
$131=730.000
$132=90.000
ok
ok
$0=10
$1=255
$2=0
$3=4
$4=1
$5=0
$6=0
$10=0
$11=0.020
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=3
$24=100.000
$25=1000.000
$26=250
$27=5.000
$30=1000
$31=0
$32=1
$100=199.100
$101=199.100
$102=199.100
$110=4000.000
$111=4000.000
$112=4000.000
$120=700.000
$121=700.000
$122=700.000
$130=810.000
$131=730.000
$132=90.000
ok
$H
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
ok
ok
Thanks
Shannon
