How can I fix error 17 in lightburn? I'm using an Ortur Master 2 Machine
The Error 17 message is coming from the Ortur engraver. LightBurn is faithfully relaying the message through the Console window.
Please request the Machine Settings report and the system Info report by typing the following into the Console window in Lighturn (Where you typed Fire…)
$i
and press Enter after each line.
You can select the text out of the Console window and copy it, then paste it into a reply here.
Error 17 is related to the $32=1 so you’re on the right track. If you have an early version of the firmware it may complain about changes.
