This has more to do with your machine than software
a) confirm you have your Xtool configured with GRBL and not GRBL M3
b) Type $$ in console and send the full output here
c) Does this happen on ALL projects?
Yes it happens on all projects.
I will do the check tomorrow.
Hi Gil, Thanks for your quick response. Here is the console output, showing before and after I typed in $$.
Waiting for connection…
ok
[xTool D1Pro:ver 40.31.006.01 B2]
ok
ok
start_home x
left limit trigged
start_home y
up limit trigged
MPos:0.000000,0.000000,0.000000
M28
$0=1
$1=0.03
$2=0
$3=0
$4=0
$5=0
$6=0
$10=255
$11=0.0
$12=0.0
$13=0
$20=0
$21=1
$22=1
$23=0
$24=25.0
$25=3000.0
$26=250
$27=1.0
$30=1000
$31=0.1
$32=1
$100=100
$101=100
$102=0
$110=18000
$111=6000
$112=6000
$120=2500.000000
$121=300.000000
$122=300
$130=432.000
$131=406
$132=0
ok
ok
your $31 is incorrect
Is set to 0.1
Which means that basicly 1% will trigger laser
in console type
$31=0 (EDITED)
Press enter
Try again engrave
Hi Gil, Thanks again for responding so quickly. I now have a different problem, of my own making I am sure. I re-added the machine as a grbl, usb, with a bed size of 430 x 850. Now it homes ok, frames as it should, but when I try to run any project it starts the fan on the laser module for a second, goes quiet, then starts the fan again after a few seconds, but does not move. This messaging system will not let me post the console read-out, it says new users can only post 1 link?
- make sure you are using the CORRECt power adapter
- post to my private messages the output of console
- make sure you are in absolute coordinates
$131=850 press enter
Your lightburn knows your machine s extended, but your firmware doesnt
I am sorry, I cannot find how to private message you.
Click my name then click
Message
nope, I am not seeing any messaging option
Shouldn’t $31=0 ? Pretty sure both my diodes are at zero. I KNOW one is.
Yes it should. ![]()
I need more coffe
possible that is because your account is new?
$131=850
$31=0
Should fix your problems
But make sure your power adapter is the CORRECT one too
ok
ok
Homing
ok
M2002 0.0.0.0
start_home x
left limit trigged
start_home y
up limit trigged
M28
M2001 0.0.0.0
ok
start_home x
left limit trigged
start_home y
up limit trigged
So machine is homing correctly
Have you adjusted $30 and $131?
MPos:0.000000,0.000000,0.000000,0.000000
ok
Starting stream
Stream completed in 0:00
ok:WORKING_ONLINE
err:limitCheck
ok:ERROR
ok
[MSG:Pgm End]
What “start from” are you using?
(check on Laser Panel)
Post a full image of your light burn with your layers panel and Laser panel in view, as well as your project. might be easier
M28
ÂŁ30=0
ok
$131=850
ok
$30 not ÂŁ30
