I actually found the solution in the forum. But when I enter this command the following problem occurs.
Typically you need to enter a value along with the $###, not just the number of the parameter. That’s why it’s giving you the error.
In your example, it would need to be $262=0 or whatever the proper variable is.
Thanks for the reply. I did that too. You can see it in the photos.
I may be missing it in the photo’s but all I can see is that you entered $262 not $262=0 as Tim said.
Ouh yes, now I see it too. But I also tried it with $262=0 and the answer was the same. My question: Can you turn off the Movement and shock detector at all?
Deleted incorrect info.
Great, thanks for the help. I’ll try it out tonight
$33 is for OLM2 (1st series 12v)
For the ESP32 chip controllers on Ortur the settings are 260to 268
To disable flame sensor $261=0
To disable Shocck sensor $262=0
What version of firmware?
Try in console
$i
$i
[echo: $i]
[ORIGIN:China]
[PRODUCER:ORTUR]
[AUTHOR:LEADIFFER]
[MODEL:Ortur Laser Master 3]
[OLF:211]
[OLH:OLM_ESP_PRO_V2.4B]
[OLM:GENERAL]
[DATE:20230417]
[SN:F82CDCD7881AC5F3C91DC7DAED351B97]
[VER:1.1f.20220325:]
[OPT:VNZHS+,63,32767,3,0]
Target buffer size found
[NEWOPT:ENUMS,RT+,HOME,NOPROBE,TC,SED,UD,CLU,WIFI,FTP,TMC=7,SD,ITG,GT,YRR]
[FIRMWARE:grblHAL]
[NVS STORAGE:*FLASH]
[DRIVER:ESP32-S2]
[DRIVER VERSION:220327]
[DRIVER OPTIONS:GIT-NOTFOUND]
[BOARD:Ortur Laser Master 3]
[TYPE:OLM3]
[CLUSTER:16]
Cluster size found
[WIFI MAC:70:04:1D:FB:4A:5E]
[IP:192.168.110.208]
[PLUGIN:Power Detecter v1.0]
[PLUGIN:Power Control v1.0]
[PLUGIN:gyroscope sensor v1.0]
[PLUGIN:Trinamic v0.09]
[PLUGIN:SDCARD v1.05]
[PLUGIN:ITG STREAM v1.00]
[PLUGIN:ESP32 WebUI v0.03]
[PLUGIN:GADGET v1.00]
[PLUGIN:YRR v1.00]
ok
Do these steps please
Ups sorry wrong picture. This was showing.
$RST=*
[echo: $RST=*]
[MSG:9:Warning: Restoring defaults]
ok
Ortur Laser Master 3 Ready!
OLF:211.
OLH:OLM_ESP_PRO_V2.4B.
OLM:GENERAL.
GrblHAL 1.1f [‘$’ or ‘$HELP’ for help]
$603=0
ok
Seems right now ![]()
Do I have to enter this command every time or is this setting now saved when i start the Laser?
Unless you clear your settings (With $RST=*)
they should be persistent
ah okay, thank you for the help ![]()
