How can we access resolution setting of LP4 to swtich between 1K, 2K, 4K, and 8K using lightburn software?
I suspect that the ‘1K, 2K, etc’ is just a way that LaserPecker has decided to name what is commonly called a line interval. I’m not sure what specific line intervals those named settings apply to - but with galvo devices, low resolution would be somewhere around 500 lines per inch, medium around 1000, and fine around 1500.
This page has some good info to review about dot spacing (akin to line interval - just another way to explain the physical resolution you’re applying, and when to know it is diminishing returns)
This page may also help: Line Interval Docs
Hi Colin
Thank you for your recommendation. I will go through the details
