I’ve downloaded single line fonts to engrave. This ttf font must have close paths (makes a loop), so the second line goes directly on top of the first.
However in reality the second line does not always go over the first. See picture below. Does anyone know how to resolve this?
Seems you have a X belt tension problem in your hands
Orturs by default do not need to be calibrated, however belt tensions might be a problem
Could you do this for me.
Unplug all wires
move head to the center of the machine
Lift the left side of the machine, so its tilter 45º. Do head move to the left by gravity alone?
Repeat on all sides please
if the movement isnt smooth and the head move by gravity alone belts might be too tight
Might be squareness too
Did you try rolling the gantry to the very back, compare left side to right side
Are both wheels touching at the same time the back frame?
