Hello group. How do I fill the area behind the SF and inside of the running ants without filling the SF? I want to keep the SF as a line.
Duplicate or offset the line you have highlighted.
Fill work as a toggle, select S F shapes and set to the same layer of the shape with the running ants, set layer to fill.
Thanks for the reply. Still working on it.
Iām new to LB. Not sure what you mean by work as a toggle or set to the same layer. Could you give me a little more detail please. Thx.
The following is worth reviewing to assist in understanding this fill ātogglingā behavior.
Layers donāt affect each other at all. If you want to see what will be filled by a given layer, turn off all the layers except that one (set them to hide).
For your specific file, youād need to duplicate the letters, and set one copy on a layer set to Fill, and the other copy on a layer set to Line.
Hereās the design (and you can tell the SF in the middle is on both the red layer and the black layer):
Red is set to Fill and black is set to Line. Hereās what it looks like in the preview (note that I set the fill to be very coarse, so you could see the outlines):
