i have a older yueming cma-1200 that runs smartcarve i would like to use lightburn can a ruida controller replace the stock yueming board
We have no way of knowing what electronics is on the current board. The motor controller IC’s could be on the board or on a separate board. If you have a wire connection diagram for the current board, then it could be done. But it will be a lot of work and some experience with electronics is required.
Have a good read
https://www.reddit.com/r/lasercutting/comments/jc3f0b/full_spectrum_ruida_upgrade/?rdt=36536
In all likelihood, yes… Most of these are relatively straight forward aside from the controller.
If you can post a few photos, we can ascertain the problems you may encounter…
These are of the panel and the control board
Uploading: IMG_0665.jpeg…
Uploading: IMG_0661.jpeg…
There is another board under to one that looks like this
Uploading: IMG_0681.png…
You need to be patient when it uploads… Wait for it to complete before you upload another one or continue the thread…
The last pic is what the board under is
