I have finally got around to trying MillMage software and this is only in the final 15 day extension. I like the software a lot and now I know it can carve 3D relief, I am sure to purchase a pro licence for it.
I set up my tool length measurement parameters and prior to my cut, I measured the length of the cutting bit. I was ready to cut and set the machine going and after being warned to turn on the spindle I was surprised to see the tool length measurement was about to take place with a spindle revolving at 18,000 RPM. What am I doing wrong?
Additionally, my machine sees the workpiece as located in the upper right quadrant rather than the mid lower centre of the work surface. Machine is a Shapeoko 3 Standard size (400 x 400mm working envelope). any help would be greatly appreciated. Thank you.
In the Job Control window, click on the Control Mode button. Then screen capture the GCode listing and add it to your Reply. That will help those with your machine type get started on a solution.
I found the same issue today. Before the job begins, there is a warning to use the tool length probe.I did this then started the spindle and noted that the tool length probe was going to measure the tool length a second time but with the spindle running.
I did my best with the control window… mac user here normally but my win 11 pro machine would not copy the amount of information in the control window. I did a few full screen shots and would appreciate knowing how to copy just the text of the control window. The four screens I copied represented about a 10th of the space needed to copy the whole window.
So would I. I should have said just copy the first part.
I looked at that first image and some of it is chopped off. I was able to see that 18Kprm was not sent until after the tool change test. What I did not see was anything except a notation for the tool change itself.
Have you made any changes to the Custom G-code window?
I am away from home, so I do not have my actual entries. I have a manual tool change sequence and no touch probe. Maybe this Thread can help get you started.
Thank you for your help. I made no changes to the software. Perhaps a developer can tell me what is the correct sequence for tool length measurement. It is not essential because I can measure the zero point of the tool with gauge blocks if I am cutting a relief the uses roughing and finishing cutters.
When using more than one tool bit, a means of getting the original tool length is essential. I make many 3D Reliefe carvings and I use a roughing and a finishing bit. The roughing gives less work for the finishing bit and level a very smooth surface requiring almost no sanding.
I set the material into the modular vice jaws and place the roughing bit into the spindle collet. I touch off the top of the workpiece and replicate that distance with gauge blocks. I now know the height of zero from the baseboard. I usually rough at 0.5mm steps and then I use my finishing bit to touch off the gauge block height as measured. Now my finishing tool is the same height and length as the roughing tool.
Thank you! My work improved after years of being not quite good enough. The change came when after a succession of different clamping methods, I got rid of the chip board spoil board and baseboard which I had used for around 3 years continuously. I paid around £600 to import the custom made fixture plate/baseboard and modular vices to the UK, from Saunders Machine Works in Ohio USA. It was an expensive undertaking but my work-holding immediately improved in accuracy and the modular vices and index pins made life simple and consistent.
I will try to fix the issue by not measuring the tool length when Millmage suggests it has to be done. That way, it will not matter when I run the software and it sends the tool to be measured at the start of the job. I will expect it and no harm will have been done. I feel sure this must be a configuration issue and I will check that too.
I think if you turn off the switches, it will not mention a tool length measure. I will just suggest you insert the correct tool. In the meantime, you can control it by turning on one operation at a time.
That is about 3 times what my CNC costs. I will just have to make-do with what I have.
Yes,
I will do that. I think my dismay was that after the tool length is measured at job set up (before the job begins) it should not be necessary to measure the tool length again (after the spindle is started).
On its face it does seem very expensive. I was working with two-sided milling at the time and I lost so much time trying to align workpieces with cutter position, that I decided to spend the money or give up two-sided milling. In truth, the chipboard baseboard could not fixate aluminium correctly and I was cutting T4, T5 and T6 material as well as brass and phosphor bronze.
Of all of the clamping arrangements I used, 3rd successful was threaded inserts in chipboard, although the holes eventually became out of round and true, thereby introducing inaccuracies. The 2nd solution was a flat clamping system by UJK via Axminster tools. The system was nicely made and it was ok for wood but not strong enough for machining metals. The best system was SMWs bespoke system. Unfortunately, I could not find any English engineering company that would make the baseboard for less than £1,200.
Work-holding is a vital element in machining. My machine is belt driven but my standard for all work is measured at ±0.001" and on occasion, when fettled, I can achieve 0.0004". I use a cylinder with a runout measured as 0.001" and my collets are high precision collets with 0.0002" guaranteed runout. When everything works together, accurate cutting is assured.
I was a maintenance tech in a machine shop in a 10 acre building. Inconel and Hastelloy were every day metals. Flying parts were both expensive and dangereous.
I consider machining with belt drives impressive for sure.
My machine was supplied with 9mm wide Gates GT2 high performance belts. It was difficult to adjust them because Shapeoko ran the belts through a 90 degree bracket, which felt wrong to my mechanical sympathy senses. However, Gates had an application that listened to the frequency of the belts and one could adjust them like that.
I changed the bracketing of the belt system on my machine so that the path was completely straight. I bought a vibration activated guitar tuner and attach that to my machine. I can adjust all three belts in around 1 minute total. I chose C3 as the hertz frequency required because Liam had suggested that a value of between 100 to 150 hertz was a good tuning of the Gates belt. My belts once tuned, tend to stay in tune for around 8 months before needing doing again.
