error:1
Las palabras del código G constan de una letra y un valor. No se encontró la letra.
Check to make sure your device profile is set to the correct device profile.
-Click “Devices” in the ‘Laser’ window
-Double click your laser in the list
-Make sure the selected device is set to ‘GRBL’
-click next until you’re done
Next, check to make sure you do not have ‘GCode’ clustering enabled under ‘Edit’ > ‘Device Settings’.
thank you very much:
The Alarm you’re seeing suggests your laser may be losing connection due to a loose USB connection, a USB port sleeping, static discharge causing the controller to reset, or insufficient power supply leading to a brown out condition.
Check your USB connection, and try a new, shielded USB cable. Route your USB so that it avoids the stepper motors or anything else that could cause electrical interference. Make sure that your machine is properly grounded. Make sure there are no devices on the same circuit as your laser that could be causing a power drop or brown out.
Here are some additional resources to help you troubleshoot these issues:
