How to troubleshoot connection issues with USB
A very common problem with Windows systems and lasers is the way Windows handles USB connections - If it thinks a connection is idle, it can put the port into a power-save mode, which can make your device stop talking to it. This is especially common with laptops.
If you are having issues where you often lose the USB connection after a period of time, try the following:
Windows 7: Disable USB Power Management on Windows 7 Machines
Windows 10: How to disable Windows 10's 'USB selective suspend' setting | Windows Central
It’s also worth noting that USB cables are limited to 5 meters (16 feet). If your cable is longer than that, you may have transmission errors or connection problems unless the cable is “active” - IE, re-transmits or amplifies the signal, and plugs into a power adapter.
Other common problems:
  • poor grounding causes electrical noise
  • chiller or air compressor on the same circuit as the controller can cause electrical noise or brownouts
If you are using a GCode device with “Home on Startup” enabled, USB connection errors will cause the connect to re-establish, and the device will re-home. This is a very good indication that you have one of the above issues.
Having Trouble Connecting Device
There was a problem sending data...again
During the engraving the system stops
Laser works then goes to busy
LightBurn just stopped in the middle of 90 min job - Screen saver to blame?
Constant disconnection from laser
Frustrated and need help
Machine disconnects while engraving
Job stops while in progress
Ortur laser, alarm 3 problem
Problem sending data to laser issue
Lightburn Wont Connect
Lightburn stops in the middle of project
Laser stop halfway through project, then returns to home
What's Going On With These "Waiting For Connecton"
I'm having a couple of problems with disconnect
Random Stopping, says it's BUSY!
While running an SVG file machine stops after 10-15 minutes and laser is on full power
Lightburn suddenly abort Engraving Process
Need help lightburn not working
Laser stopping after 3 lines are burned
Lost Connection xtool d1 pro
Problems for a newbie
Laser does not stop between letters in line engraveing
Issues engraving images
Lightburn with GRBL controller goes nuts
Stopping in the middle of a burn
C3D Laserboard Crashing
Lightburn stops
Laser stops halfway through project
Burning a large job
Lightburn or laser stops engraving after 24 minutes, project is not finished Ortur
My k40 laser stops operating when using move commands
Engraving screws up when using the play button in lightburn, but works fine on the controller
Laser stops, cant find the reason
Laser stopping mid way through job unable to restart from same position laser status *busy*
Machine just stops
Laser stops working
Stops burning at 40% job done
Cannot connect to engraver
My laser had a hiccup, sort of
G code words missing /
Ortur LM3 quits before job finished
Laser heads for top left when set up for bottom left
ALARM:3 Reinicie mientras está en movimiento. Grbl no puede garantizar la posición. Es probable que se pierdan pasos. Se recomienda volver a determinar el autoguiado. ok
My machine is shutting off after a couple minutes of burning. I turned the batter saver on never and screen shotoff as well. What else could be causing this. It wasnt doing this a few days ago
Sculpfun s9 connection problems after lightburn uprgraded to nevest version
Sculpfun s10 and lightburn
Laser turning off
Can not get my Boss Laser LS2440 to connect to Computer
Struggling Newbie
Neje Max4 stops during or at the end of the project
LIghtBurn hanging after less than 3 minutes
First job stopped before complete with no error code
LaserCO2 ARDUINO stopped
Trocen TL-3120 problem
Trial version not compatible with TopWisdom?
Job failure without error msg
LightBurn quits
Help Using Ortur laser master 2. keep getinig error codes
Code line [xTool D1Pro:ver 40.31.006.01 B2]
I problem with mi longer ray5 20w
Scan for my laser but its not being found. And yes, its plugged in!
Laser intermittently stops before job is complete
Neje Master lightburn issue
