I swapped boards and now I’m losing details
Do the wings show up if you rotate your image? I wonder if you need to enable the special engraving mode mentioned in this forum post: Not engraving thin lines perpendicular to scanning - #2 by Stroonzo
If this issue also shows up in RDworks, you may want to confirm that your power supply is wired correctly. This user was able to achieve tiny engravings like yours by switching to PWM-signal instead of analog:
