prior to documenting my issue in detail was curious to know if anyone else has reported an image that flips when you change devices I found one ( 2 lasers- Have to flip image horizontally each time I switch lasersthat is similar, but on my machines it flips certain components… like the outside cut lines will be correct but the text will be flipped both ways,(shift+h, Shift+V) )… example, i have multiple lasers, some basic diodes and a c02. this happens most times i change between devices.
That is normal behavior when changing between machine types. The machine origin is in different corners on the different machine types. A simple way I have found to avoid this issue is save the file, click the new button, switch your machines then reopen the previously saved file.
