Hi, I have problem with LightBurn (1.1.04 but also previous one) on Linux (Manjaro), connected to a Ortur LM2Pro (updated to the last firmware).
All operations as home, Jog, frame… are working, so connections is OK.
When I start my job it is executed for a while, but it stop working after few seconds/minutes.
The software reports busy, the console report no more gcode message and no errors, but all is off.
Some time pressing stop it exits (see log 2) some time no.
The machine is working because closing and restartin LightBurn it restart to communicate and jog.
console.txt (37.4 KB)
console2.txt (38.5 KB)
Changed several usb cables but not solved. I attached the linux console output from where i executed LB.
Not all the files present the problem. Some files are completed with no problems. I attach also the file I’m working on. It fails during the first pass of the first external perimeter.
I then changed OS (same notebook, but win10 with same LB version and same file). In this case no problem and I can complete my job.
But for me use only windows version is not an option, because I create my files and I work 99% on linux.
I’m a sw developer with experience in serial protocol too, so please tell me if I can investigate or I can do more debug.
smartphone_stand1_3mm.lbrn2 (13.6 KB)
The current file settings are speed 2000@5% to not waste other material, but the same with original settings 200@95%
