When I start up my machine in the box where it states what it is doing it comes up with (Increasing Pull-Off or check wireing) how do I increase the pull-off?
GRBL configuration $27 sets the pull-off distance in millimeters. You can set this from Edit->Machine Settings or by entering $27=NUMERICVALUE
in Console where NUMERICVALUE
equals the distance that you want.
However, unless you’ve modified your machine it’s unlikely that this should be required. What’s the history of the laser? Had it been working correctly or is this new?
Can you copy the full output in Console including messages from earlier and paste in a reply here?
