Hello
I would like to buy Lightburn but for my computer in my garage which is not connected to Internet how to do?
thank you
LightBurn provides a way to use the software with an offline activation license. âOffline Activationâ means that the computer doesnât have to be connected to a network at all. This can be found under âHelpâââLicense Managementâ.
Get an AP range extender for your garage - ~$25-50
I use cheap second-hand wifi routers that support extending the wifi
Hello
Thank you for your answers
but after if it has an update on my pc workshop or it does not have internet how do we reinstall everything?
thank you
You would do the same as you do initially, but I may not be understanding your question correctly.
Hello
redo like the first time so ask again for an offline activation?
thank you
Sorry, I have not made this very clear.
To update LightBurn on a system using the Offline Activation option, you simply need to download and transfer the new release to the offline system and run the install again and LightBurn should keep the activation without you needing to do anything further.
ok merci
