Is there a way to lock the laser head in it's position?
When I finish cutting a job I like to check to see if the ply cut all the way through. If it didn’t I’ll make another pass to finish the job. The problem if I bump the laser head the next cut, if needed, won’t align.
Here’s what I do now. If there is graving involved I’ll turn that off and set the cutting passes to one. Then I start the laser and quickly pause the laser to lock in in place.
That works but I was wondering if there is a button I’m missing to do this in just one step.
BTW, I do have the laser set to current position when I start a job
What i do is raise the material just a little above the honeycomb. Even just a couple of pennies will work. That way after the cut is made it drops down. If it doesn’t drop i know it wasn’t cut all the way through. That also makes the cut a little cleaner and tends to eliminate small spots in the cut line that may not cut all the way through because of material inconsistency
I can only say how I do it, I use absolute coordinates, and position my material in a way that I can pick it up and put it back to its exact last position.
Practically speaking, I have aligned my work bed so that it fits exactly to the geometry of my laser, i.e. 0:0 is in the home position and all material is positioned in this position with a 90 degree corner. Works perfectly - here.
Setting the GRBL $1 parameter to 255 will keep the stepper motors powered continuously, which should lock the laser head in position firmly enough to resist casual bumps.
You can examine & set that value in Machine Settings or interactively through the Console.
You can also set the Finish Position to park the laser head out of the way at the end of a job.
However, as other folks have noted, repeatability requires putting the material back in exactly the same location. Fixtures and fences will become your friends forever.
Repeatability also depends on accurate homing when the controller starts up, so that two runs of the same job start from exactly the same position. If the machine homes inaccurately or not at all, fixing that is the first step.
I do that too with the material, sadly it doesn’t help if I bump the laser head with clumsy fingers
Interesting, I’ll have to give that a try. Thanks
If you use absolute coordinates, it does not matter that you move your laser head. The machine/job always starts in exactly the same place and if you have placed the material as mentioned in the same position, i.e. for example with the same corner of the material in the same corner as 0:0, then it works fine. In the preview window you can afterwards decide from where the laser should resume the task.
As long as you only move with the move arrows and not by hand. If you move it by hand you most rehome before further operation.
