I have a Ortur Laser master 2. I just got it finally up and running. Had a new controller board sent to me. Machine did not work on arrival. Anyways I am trying it out for first time with a Ortur group file for burning a grid on board machine is mounted to. The laser will burn the vertical lines and horizontal numbers But when it goes to upper left to start the Horizontal lines and vertical numbers it briefly starts on first number then quits. I have tried 6 times and it stops same place everytime. I have upgraded to latest firmware 1.34.
I get a H and a unlock command in window of console. Any help Please
Greetings, thats odd
Could you tell me please if any other error happens in console, or it simply stops?
Try Enable “Show all” in console
And reduce the power to 1% on cut setting so it goes through the motions but doesnt burn the materaial
Also you didnt upgrade, but downgrade to 1.34 i wonder however if you used the right file
Could you do 2 things in console and send me output
- $# press enter
- $$ press enter
Copy paste the whole output pelase?
Regards
