Issue with Power Scale
Hi Guys,
Ok I think I may be having power issues. I have a G.Weike LC1390N with a reci 100w tube, ruida controller and using lightburn.
I set up a power scale (using the power scale feature in lightburn) to test because I was having difficulty with cups this morning. For some reason the machine doesn’t seem to be adjusting power properly. It seems as though the only thing that is effecting the fill is the speed. Any thoughts?!
i had this recently in a Ruida controller…
… it turned out that i had accidentally touched the manual power switch on the front panel next to the ammeter.
i had set it to manual , so lightburn was not able to control it.
may be worth checking that
I’d check controller settings, too.
