Issues when Chuck is connected
I have a Ortur LM2P running a Aufero LU2-10A, using the latest version of LB.
Issue: My laser works flawlessly when doing flat objects. When I hook it up to the Chuck. It will do 1 of 3 things. 1- Stop mid-burn and just shut off. 2- About mid-burn it will traverse down the axes and continue burning. 3- It will execute fine.
Having multiple issues cited in one thread whose title relates to only one of them will be difficult for anyone to answer all of them in one place.
I would edit your original post, i.e., remove issues 1 & 3 from it and let issue 2 be a standalone topic. Then post the other issues in their own threads.
I’m not going to be looking for issues/solutions whose titles don’t reflect my issue. Hopefully, that makes sense, but to clarify, if my problem is like your issue 3 (internet+engraving issues), I absolutely would never open “Issues when Chuck is connected”.
That is not a valid GRBL Command. I’m not at my laser now to test, but I believe $I will get you what you want. Thath’s the letter I for info, not a 1.
Valid point, thanks
